I am wondering if it is possible to draw a box around an equation in Obsidian. I am using the Latex format… but I have also seen the term MathJax thrown around. Not sure if I understand correctly, but MathJax renders Latex form equations correct?
Is it possible to draw a box around an equation written in Latex format?
Yes, Obsidian uses MathJax for LaTeX math rendering.
To draw a box around a LaTeX equation simply put it in argument of the \boxed command:
$$ \boxed{E = m c^2} $$
It will be rendered as
Screenshot 2022-02-21 at 12.46.52
A list of supported TeX/LaTeX commands can be found here:
http://docs.mathjax.org/en/latest/input/tex/macros/index.html
