Create Bases with Templater
Hey,
I’m trying to use Templater to create a template that can also generate a base. Unfortunately, my attempt to create the base via:
await tp.file.create_new(tp.file.find_tfile("landingpage/landing-base-template"), title + '-base.base', false, app.vault.getAbstractFileByPath("_data_/bases"));
failed because the file extension is not set to .base, but rather .base is written in the file name.
Does anyone have any idea how I can create a base with Templater?
You have to use the obsidian api, instead of the templater api:
const basePath = `Test.base`;
const baseContent =
`filters:
  - type: table
await app.vault.create(basePath, baseContent);
_%>
Thanks for your reply. Unfortunately, I haven’t been able to try it out yet, but I’ll give it a go soon.
