Create a note for a folder
Hello,
I am coming from Trilium Notes and because it is SQLite based it is possible that a note can also be a folder (containing child notes).
And although I do like the fact that obsidian uses simple files for the content, I do miss the possibility to have note content on a folder level. I use that a lot in Trilium.
Would it be an option to have for every folder you create in your vault a hidden md file is created in that folder (for example .foldername.md or maybe even a fixed name like .foldertext.md or so). And when you click on the folder the tree is not only opened but the content of that hidden md file is also presented.
My tree might looks like:
  • Project A
    - sprint 1
    - sprint 2
    - sprint 3
Now I have to create a sprint 1 file in my sprint 1 folder (which contains multiple files ect). That is not logically for my. Specially as you cannot force a note to be at the top of the child files.
For me this functionality would make my use of folder a lot easier and self-explaning because you define what you mean on a folder level.
I just thought this up and would lik e to know if anybody sees the value in this. Otherwise I might have to change my working habbits :-).
Let me know.
Kind regards,
JeRoen
A post was merged into an existing topic: Markdown Content for Folders
