- Probably install Gentoo Linux on M1 macbook? (oof. probably it doesn’t make anything with CPU’s arch, but installing gentoo is still oof)source
- Launch Obsidian-1.4.5-arm64.AppImage
- Get
./Obsidian-1.4.5-arm64.AppImage: error while loading shared libraries: /usr/lib64/libz.so: invalid ELF header
error.
Yes I did search for similar issues using keywords.
Obsidian launch
Obsidian doesn’t launch
Sorry but I cannot copy this info since I cannot launch Obsidian.
Basic details about my setup:
- Macbook Air 13 2020 M1
- Gentoo Linux (kernel: 6.4.0-asahi-10-edge)
- Wayland, Hyprland WM
Mentioned file from that error comes from sys-libs/zlib
package which is 1.2.13-r1
version. zlib was compiled with this flags: +minizip -static-libs
means set, -
means unset).
I guess this would not be an issue if I would compile obsidian myself but obsidian is not source-available product
Thank you for this product, even though I haven’t tried it yet
