echej
February 15, 2021, 12:30am
1
First I thought it was bug
Go to Make a dummy index column - python
Copy the second code block to obsidian (using control + C, control + V)
What I got (slashes are added to the code)
from sklearn.datasets import load\_boston
boston \= load\_boston()
df \= pd.DataFrame(boston.data, columns\=boston\['feature\_names'\])
What I expected
from sklearn.datasets import load_boston
boston = load_boston()
df = pd.DataFrame(boston.data, columns=boston['feature_names'])
My os Pop OS 20.10 Linux, I use flatpak distribution
But Obsidian just doesn’t have this functionality Zettlr
Copying code block from this site
results in
instead of expected intended code block as implemented in Zettlr (result is a code block starting for tabs)
So my request was to implement copying code blocks in a rich mode as code blocks
It’s interesting… I think there may be something website-related there that doesn’t recognize the code block as such, e.g. try copying code from this site for example (which at least for me it works). I’ll modify your title a little bit to provide more context.
echej
February 15, 2021, 12:35pm
4
Indeed, this may be some obscure border case.
Copying modern sites with code work well as you pointed me.
The topic may be closed, I think.
