Converting a canvas card to a file does not follow the default location settings
When converting a card on a canvas to a file the new file does not follow the default location settings and saves the file to the vault root. Is this intended behavior?
Moved from Help for not following the bug report template.
When you asked on Discord someone responded that they didn’t see the same behavior. Have you tried the troubleshooting steps in the Obsidian debugging guide?
