I often create embedded code block bases to localize a base to a certain note. I only create a base file if I find I will use it across multiple notes or will make it abstractly referential (i.e., file.this).
I have found that on occasion I want to convert that code block base to a standalone base. Unfortunately, to do that I need to reproduce the entire base from scratch or open the base file in an external text editor.
Two possible solutions:
Solution 1: Add a button that converts the existing embedded code block base to a base file.
Solution 2: (Preferred) Make Base files have editable code block inside of Obsidian. There is currently no way to edit the code block of a Base file via Obsidian.
The current way to do this is opening and editing the system file outside of Obsidian, i.e., on the Base file, selecting “More Options > Reveal in Finder > Open With…” [e.g., Sublime Text].
