Convert a Dataview list with into internal links using Templater
Hello,
unfortunately, I’m not making progress with my problem and I don’t know enough about it. That’s why I could use your knowledge.
I’m trying to convert a DataView list with linked notes into internal links using Templater.
For listing in DataView, I’m using the following:
LIST from [[]] and !outgoing([[]])
SORT date DESC
LIMIT 8
With Templater, this list should then be converted into internal links.
I know that, for example, the following script works for Templater when listing tags:
const dv = app.plugins.plugins[“dataview”].api;
const query = ‘list From #type/recipe’;
let out = await dv.queryMarkdown(query)
tR += out. Value
I have adapted this script:
const query = 'LIST from [] and !outgoing([]) SORT date DESC LIMIT 8 ';
tR += out. Value
However, it seems to refer to the template itself and not to the note where I apply it. So, it doesn’t display anything.
What do I need to do for Templater to dynamically apply [] to the desired note?
Insert and define tp.file.title in []?
Thank you very much for your help.
If someone in the future is still looking for an answer, @Joschua was able to help me find one.
<%* const dv = app.plugins.plugins["dataview"].api;
const fileTitle = tp.file.title;
const query = `LIST from [[${fileTitle}]] and !outgoing([[${fileTitle}]])`;
const out = await dv.queryMarkdown(query);
tR += out. Value;
In this context, I also found his blog post very helpful.
Thank you very much!
