I’m sorry, I don’t know how to cause the bug, only how to detect that the bug is happening. ![]()
Yes. I have a vault of 5230 files, but it is currently working in Restricted Mode, no CSS Snippets, Default Theme in use.
Expected result is that Obsidian is aware of new notes added, or new edits of existing notes. When the bug happens, certain features stop being ‘aware’ of new notes or that notes have been modified.
For example:
- I expect Base Views to be always aware of new notes which match their filter criteria
- I expect the Rebuild button (Settings → Files and links → Rebuild) to refresh / rebuild the index (which I am assuming the index underlies the bug) when clicked
- When I have plugins enabled, Dataview blocks which display all the files created today will not display notes created from when the bug starts, onwards. In Notebook Navigator, when I add an image to a note, NN displays usually displays it as a thumbnail in the file entry in the file listing. When the bug happens, this stops working. Etc.
When the bug has started to happen, Base Views which should display new notes, won’t - they will only display notes that Obsidian was aware of before / until the bug presented.
Similarly, clicking on the Rebuild button (Settings → Files and links → Rebuild) will do nothing when the bug is happening. Clicking on it multiple times will result in nothing.
To fix Obsidian when the bug is happening, I have to do one of the following:
- Force quit Obsidian and then open it again
- Or, switch to a different vault and then switch back again
Doing either of the above will make Obsidian behave as expected for a period of time until the bug happens again and it stops being ‘aware’ of new notes etc, requiring another force quit again and again and again. This bug is happening multiple times a day unfortunately.
Operating system: ios 18.7.2 (Apple iPad13,4)
Obsidian version: 1.10.6 (256)
API version: v1.10.6
Catalyst license: supporter
Base theme: light
I have also tried entirely removing Obsidian from my iPad and reinstalling it. The bug still happens after doing this.
The vault is stored locally on my iPad - i am not using iCloud etc to store and sync.
This issue was happening long before Bases were introduced as a feature - as noted above, previously most commonly I would be aware of it through Dataview blocks not showing newly added / modified notes. E.g., on my note for a specific book, I would have a Dataview block which would list all notes for books by the same author. At various intervals I’d add a book note which should have been listed, and it wouldn’t until a force quit and restart.
