Constant issues with Publish command loading
Publish changes to Publish. Sometimes the box comes right up, but most times it simply will not load, ever. I sync my vault to iCloud which may be the issue, but I don’t know how I’d determine that. Finder says that iCloud is synced.
Starting in safe mode doesn’t help.
Sometimes restarting my computer fixes it, sometimes it doesn’t.
It doesn’t seem like the amount of changes is related. Sometimes this happens after a single word edit, while sometimes it loads right away after a weeks worth of note taking.
enable safe mode and restart obsidian.
Do cmd-opt-i and look into the the “console” tab. See if there are any errors there as your try to upload with publish
