When the focus is on a Modal\Dialog window, other panes should not be affected.
Notable examples
  • Delete modal window
  • Settings modal window
  • Have a pane open in edit mode
  • Click vertical tripple dot
  • Choose “Delete file”
  • Repeatedly press “Tab” key
  • Tabs are written into underlying file
Ideally, tab would navigate among available options/buttons.
Associated request: Keyboard shortcuts for dialog modals
But most importantly, Dialogue should block modification of underlying window as described in https://en.wikipedia.org/wiki/Modal_window
By use of keyboard, unexperienced user can cause a lot of unnoticed edits / data-destruction in greyed-out underlying window.
  • Operating system: Windows 7
  • Obsidian version: 0.10.6
Repro:
  • Obs 0.10.8
  1. Open note & place cursor in note
  2. Open settings via hotkey (e.g. ⌘cmd+, on macOS)
  3. Settings dialog opens
  4. type some stuff on keyboard, it passes thru the settings modal dialog and into the note, potentially damaging it
Video:
will be fixed in 0.10.9
Not sure but perhaps it would be convenient to add standard Keyboard shortcuts for dialog modals while working on modals.
