I like to have a H1 heading at the top of each note that is the same as the note name. Unfortunately, if I rename the note at any point I have to remember to change that header as well.
I would like a feature that will automatically create a H1 heading the same as the note name and update it if you renamed the note. This could also be extented to YAML Frontmatter title:.
there is already a feature request for his.
Please, consider complementary simple request that will make this one much more useful in the future:
By putting title directly in “title” field instead of “aliases” field, we will have it ready when this request is implemented.
When we will see titles daily, we will want them to match in quick switcher and in link suggestions.
“Title” field is well defined, manageable by plugins so in case of need we would be able ourselves to fill missing titles by data extracted from markdown by some pl…
Cheers. I looked but couldn’t find the right thing to search.
@NotBoolean If you want to automatically duplicate filename into note content by template, then the following thread might help you:
Do you mean {{title}}? Use this in templates it will auto insert the “title”(filename).
Related feature request:
Use cases:
Use existing databases with specified titles effectively, eliminate the need to [duplicate title into aliases field and then maintain them in sync].
This feature would be simple initial step towards support for vaults with UID based filenames (Zettelkasten).
Proposed solution:
Add option to treat YAML “title” field as one of aliases.
i.e. when the option is toggled ON in settings (or in some config file) for given vault, then return title as match in auto-completion during linking …
