I started using the Full Calendar (FC) plugin for obsidian to create a daily calendar that I can put in a sidebar. With FC, it creates a new note for every event that you add to the calendar, where the frontmatter of the note is used to place the event on the calendar in the correct place, with the correct times, day, titles, recurrences, etc.
If the event is a single instance event, its note has a frontmatter key “date:” where the value is the date of the event.
If the event is a recurring event, the note DOES NOT have the “date:” key, and instead has “daysOfWeek:”, “startRecur:”, and “endRecur:” keys. The start and end recur keys have values in date format. The Days of Week key has a value in list format, where the recurring days are represented by a single letter. EX:
daysOfWeek:
- F
- W
- M
I am trying to create a template for these created “event notes” that places links to the events’ associated daily notes. For the NON-recurring events, this is easy to do through a reference to the “date:” frontmatter. i.e.
Date: <%* if (tp.frontmatter.date) { %> [[<% tp.frontmatter.date %>]] <%* } else { %> <%* } %>
However, it is tricky when trying to get all the dates for an event that recurs since I have to somehow combine the start and end date, with the letters in the daysOfWeek property to create a list of the dates. I will show how I have found a workaround below, but it is way too unwieldy and long. I do not have any formal coding or javascript experience, and have just pieced together some knowledge from the internet and have hit my limit.
The problem is that I am doing each piece of the work separately and “by hand” and it creates huge blocks of codes that feel excessive. I have to do each day (Sunday through Saturday) separately. And then for each day, I have to go through each successive week individually. It creates huge blocks that cant be the best way to do this.
Is there a way to take what I have done below and simplify it? Or automate it? Or just any other way to do this?
Thanks for all the help!!
Parts Used:
StartRecur date: <% tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>
EndRecur date: <% tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.endRecur, “YYYY-MM-DD”) %>
The date of the Monday of the week in which StartRecur happens: <% tp.date.weekday(“YYYY-MM-DD”, 1, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>
The date of the Monday 15 weeks after StartRecur happens: <% tp.date.weekday(“YYYY-MM-DD”, 106, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>
every other week between 0 and 15 are also included in the below explanation, but the only change is the “offset” value of the templater script.
My Understanding of how the Program works in laymen terms:
Level 1:
- IF
- daysOfWeek frontmatter exists,
- The Monday of Week of StartRecur is same or after StartRecur,
- daysOfWeek includes “M”, AND
- The Monday of 15 Weeks after StartRecur is same or before EndRecur
- THEN list
- Every Monday between Week 0 and Week 15
- ELSE Level 2
Level 2: - IF
- The Monday of 14 Weeks after StartRecur is same or before EndRecur
- THEN list
- Every Monday between Week 0 and Week 14
- ELSE Level 3
Level 3:
Level 15: - IF
- The Monday of Week after StartRecur is same or before EndRecur
- THEN list
- Monday of Week of StartRecur and Week after StartRecur
- ELSE level 16
Level 16: - IF
- The Monday of Week of StartRecur is same or before EndRecur
- THEN list
- ELSE display “blank”
Selections from the code/program I am using:
Very Beginning (This part captures 15 and 14 weeks after StartRecur)
if (tp.frontmatter.daysOfWeek)
if (moment(tp.date.weekday(“YYYY-MM-DD”, 1, tp.frontmatter.startRecur, “YYYY-MM-DD”)).isSameOrAfter(tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.startRecur, “YYYY-MM-DD”)))
if (tp.frontmatter.daysOfWeek.includes(“M”))
if (moment(tp.date.weekday(“YYYY-MM-DD”, 106, tp.frontmatter.startRecur, “YYYY-MM-DD”)).isSameOrBefore(tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.endRecur, “YYYY-MM-DD”))) { %>
[[<% tp.date.weekday(“YYYY-MM-DD”, 1, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 8, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 15, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 22, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 29, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 36, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 43, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 50, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 57, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 64, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 71, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 78, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 85, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 92, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 99, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
[[<% tp.date.weekday(“YYYY-MM-DD”, 106, tp.frontmatter.startRecur, “YYYY-MM-DD”) %>]]
else if (tp.frontmatter.daysOfWeek)
if (moment(tp.date.weekday(“YYYY-MM-DD”, 99, tp.frontmatter.startRecur, “YYYY-MM-DD”)).isSameOrBefore(tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.endRecur, “YYYY-MM-DD”))) { %>
SKIPPING TO END (The below portion capture the week after and week of StartRecur) (The omitted portion repeats the patttern)
if (moment(tp.date.weekday(“YYYY-MM-DD”, 8, tp.frontmatter.startRecur, “YYYY-MM-DD”)).isSameOrBefore(tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.endRecur, “YYYY-MM-DD”))) { %>
if (moment(tp.date.weekday(“YYYY-MM-DD”, 1, tp.frontmatter.startRecur, “YYYY-MM-DD”)).isSameOrBefore(tp.date.now(“YYYY-MM-DD”, 0, tp.frontmatter.endRecur, “YYYY-MM-DD”))) { %>
<%* } else { %>
“Blank”
Final Thoughts
As far as I can tell, this works! I’ve tried different test files using this code for Monday and Tuesday. But even one day of this is wayyyy too much, and I’d like to be able to do it for all 7 days. Any help would be greatly appreciated. Thank you!!
