Comparison of 2 promising nutrition tracker (Macros and Food Tracker)
Hi everyone,
I’m looking to track my eating habits for two main reasons:
  1. To better understand my fat and sugar intake and use trend data as motivation to gradually improve my diet.
  2. To identify patterns between what I eat and any physical symptoms, in order to spot possible intolerances.
Right now, there are two plugins that look promising for this:
  1. Macros
  2. Food Tracker
    (The “Food Diary” plugin seems very basic in comparison, with far fewer features.)
Even though both plugins already exist, I think this still fits best under the “Plugin Ideas” section — hopefully that’s the right place for it.
Below, I’ve listed the features I’d like to see in a food tracking tool, and how I think each plugin currently handles them. If I’ve missed anything, please correct or add to the list.
Features I’d like:
  • Meal timestamps:
    To link meals with symptoms, I need more than just daily nutrient totals — the exact time of consumption is also important.
  • Symptom tracking:
    Ability to log symptoms and analyze them alongside meals. The analysis itself could be done using AI, so the plugin doesn’t need to provide that functionality — it just needs to make symptom logging possible.
  • Nutrition database integration:
    • Multi-language support.
    • More than just macros (protein, fat, carbs) — e.g. also calories, fiber, sodium, sugar.
  • Barcode scanner:
    If a food isn’t in the database, scan its barcode to pull in nutrition info. Many mobile nutrition apps already offer this.
  • Past-days visualization:
    Graphs or charts showing eating patterns over time.
  • Fluid intake tracking.
  • Custom default portion sizes.
  • Export option:
    Export per-meal nutrient totals to CSV so the data can be used elsewhere — e.g. combining it with symptom tracking for AI analysis to find possible links.
Feature Macros Food Tracker
Meal timestamps No — daily totals only. No — daily totals only.
Symptom tracking No, but since it’s open .md format, you can add symptoms manually in the files. Analysis would be up to you. Same as Macros — you can manually add symptoms in .md files, but there’s no built-in analysis.
Nutrition database integration Fat Secrets API (paid for researchers, free version here).
Multi-language: No (English only, no local products).
Extra nutrients beyond macros: No
OpenFoodFacts (free community project, may have some inaccuracies).
Multi-language: Yes (includes many local products).
Extra nutrients beyond macros: Yes — also tracks fiber, sodium, sugar.
Barcode scanner No No
Trend visualization Yes — very nice. No
Fluid intake tracking No No
Custom default portion sizes Yes — works very well. No — must manually enter amounts for every ingredient/food (time-consuming).
Export function No No
My takeaway
Macros — Pros:
  • Beautiful visualizations for both daily totals and trends.
Macros — Cons:
  • Only English-language foods/meals in the database.
Food Tracker — Pros:
  • Clean, minimal interface; leverages Obsidian’s built-in features.
  • OpenFoodFacts database seems more promising:
    • International community project
    • Multi-language
    • More detailed nutrition info
Food Tracker — Cons:
  • No trend graphs.
  • No custom portion sizes.
Questions to Food Tracker:
  • Why use tags? Isn’t that an outdated approach? Wouldn’t using properties be more future-proof?
What’s missing in both:
  • Meal timestamps
  • Symptom tracking
  • Export function
Nice-to-haves:
  • Barcode scanner
It’s very hard to track your food.
I suggest something like Cronometer that has the most reliable database.
and then you can just export the data to Obsidian.
I agree that these two are great. My wish list is for Food Tracker to have a couple of code blocks for visualization similar to Macros (a daily and weekly note-type chart), but I love how easy it is to manually add foods via the FT formatting!
Edit: I switched to Food Tracker from Macros after realizing that Macros doesn’t actually store the macros in the notes, so if you uninstall the plugin or move to another app, that data is actually lost. Yes, the code block has the food name and portion volume, but no macros. Food Tracker stores this in the YAML of the periodic note making it truly future proof.
I’ve also really decided that I much prefer not having large charts and tables in my notes that Macros does (it’s a personal preference, for sure), if I need to see trends, I use the provided ribbon icon for Food Tracker.
