While organizing API documentation, I recently switched from Typora to Obsidian. I’ve also noticed some noticeable differences when copying web content and converting it to Markdown compared to Typora or other Markdown editors (like forum Markdown). Specifically:
Copy the following content:
Obsidian:
typora:
It can be found that typora is correct when converting the request example and uses code blocks, while Obsidian uses code text, which causes them all to be displayed together.
Finally, I would like to ask if there is any such situation, and any plug-ins or other optimization methods?
After updating, paste the text under this forum editor, the format is correct…
Additionally, using Obsidian’s browser extension did not yield the desired results. I believe this may stem from differences in how the official implementation handles Markdown recognition. I hope this functionality can be fixed. Thanks!
