I have looked in the obsidian options and also in the documentation and I can’t find anything that helps me with that.
Move from one window to another with a keyboard shortcut.
Do you mean moving through tabs?
Ctrl+Tab: Moves to the right
Ctrl+Shift+Tab: Moves to the left
No, I mean moving windows, tabs effectively move with what you mentioned. A new window is created with Ctrl+Shift+n I want to be able to move to that window with the keyboard
Pane Relief will let you jump across tab groups and focus on a tab (up to 9 easily) using alt/optn+1~9
. Give that a try.
Thank you very much, although I find it surprising that this shortcut does not exist natively in obsidian
Yeah, it’s bizarre that the native cmd/crtl+1~9
only works with tabs in one tab group. Halfway there.
