Command “Toggle checkbox" fails to recognize checkboxes inside callouts titles
  • Create a callout with a checkbox
> [!faq] - [ ] Checkbox
  • Place cursor on that line and run command “Toggle checkbox status”
Y
(New empty restricted vault)
See the checkbox toggled.
Starting form both unchecked or checked, running the command results :
> - [ ] [!faq] - [ ] Checkbox
Tested on both Windows and Android version 1.8.10.
Obsidian version: v1.8.10
Installer version: v1.8.3
Catalyst license: none
It did work before, I was using plugin https://github.com/lhansford/obsidian-checklist-reset to reset all checkboxes but it stopped working recently (max few months).
Not finding any way to edit so I’ll add:
Title could be instead: ‘Command “Toggle checkbox" fails to recognize checkboxes inside callouts titles’
Sorry, you are relying on an unsupported feature
We don’t support checkboxes in callout titles.
I don’t consider this a bug.
You can open a FR and ask for supporting this.
