I often open command palette just to see if a given action is already implemented, try a few different names, and most of the time, there’s already a command. The palette will show if a command already has a hotkey, which is great, but if I decide I want to change that hotkey, or map a new one, I then have to go through the settings menu to the Hotkey page and search for the command again before setting the new hotkey.
I would like to be able to right click (or some other hotkey) within the palette to set a new hotkey for that command. I can’t think of any other actions I’d like to have available from the palette, but if there are any other suggestions, it may be more prudent for right click to bring up a context menu instead.
