columnSize Attribute duplicated, when resizing column
When I use a base with inline syntax and resize a column, the columnSize Attribute in the YAML is duplication each time I do that. (See Additional Information)
Because of the wrongful syntax, the base does not work anymore, until I manually remove the duplicated lines.
No
Only one version of the columnSize Attribute
An additional Attribute every time I resize a column.
Obsidian version: v1.9.2
Installer version: v1.8.9
Operating system: Darwin Kernel Version 24.5.0: Tue Apr 22 19:53:27 PDT 2025; root:xnu-11417.121.6~2/RELEASE_ARM64_T6041 24.5.0
Language: de
Catalyst license: supporter
Insider build toggle: on
Community theme: Obsidian Nord v0.2.0
Snippets enabled: 2
Plugins installed: 32
Plugins enabled: 25
1: Dataview v0.5.68
2: Commander v0.5.4
3: Calendar v1.5.10
4: Style Settings v1.0.9
5: Templater v2.12.1
6: Editor Syntax Highlight v0.1.3
7: Metadata Menu v0.8.9
8: Actions URI v1.8.1
9: Supercharged Links v0.12.1
10: Folder notes v1.7.35
11: Periodic Notes v0.0.17
12: Reveal Active File Button v2.0.3
13: Editing Toolbar v3.1.16
14: File Explorer Note Count v1.2.3
15: Mononote v1.2.2
16: Remember cursor position v1.0.9
17: Iconize v2.14.7
18: Omnisearch v1.27.1
19: Doubleshift v2.2.1
20: Bible Linker v1.5.14
21: QuickAdd v1.13.3
22: Projects v1.17.4
23: Paste URL into selection v1.7.0
24: Linter v1.29.2
25: Text Format v3.1.0
filters:
  and:
    - type.contains(link("Entdeckung"))
properties:
  file.name:
    displayName: Entdeckung
  note.area:
    displayName: Bereich
  note.topic:
    displayName: Thema
  note.day:
    displayName: Tag
  - type: table
    order:
      - file.name
      - area
      - topic
      - day
    sort:
      - column: note.day
        direction: DESC
    columnSize:
      file.name: 505
      note.area: 139
      note.topic: 257
      note.day: 94
   columnSize:
      file.name: 505
      note.area: 139
      note.topic: 185
      note.day: 94
   columnSize:
      file.name: 505
      note.area: 191
      note.topic: 185
      note.day: 94
   columnSize:
      file.name: 505
      note.area: 191
      note.topic: 185
   columnSize:
      file.name: 505
      note.area: 121
      note.topic: 185
   columnSize:
      file.name: 505
      note.area: 121
   columnSize:
      note.area: 121
Duplicate of:
