Create New/Open any vault in 1.5.6/1.5.7
Create a heading (#### A)
Create a table below with a row
Align any column left/right/center
→ There will appear a newline in-between the heading and the table. If you remove the newline (source mode), the table renders fine, but any time you Align the column it adds the newline back
This happens in all vaults in 1.5.6/1.5.7, with any size heading. The same happens with text but you need that; it just also happens for headings which it shouldn’t
Nothing, just align the column
It adds an unnecessary and undesired newline on top of the table any time you Align a column
Obsidian version: v1.5.7
Installer version: v1.4.13
Operating system: Windows 10 Home 10.0.22631
Catalyst license: insider
Insider build toggle: on
I don’t recall this happen in the stable version
