Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
- Developer issues with the API should go here
- Themes and Custom CSS issues should go here
- Translations issues/improvements should be posted here
- Obsidian Clipper Bugs should be posted here
- Obsidian Importer Bugs should be posted here
- We only accept bug reports that are reproducible with the installation methods we provide on our website. If you obtained obsidian elsewhere, you must reproduce the problem with one of the officially supported installation methods.
- Create two notes with collapsible elements.
- Add properties to the frontmatter in one of the notes.
- Click on the collapsible elements.
- In the left note (without properties), the collapsible elements work normally when collapsing or expanding them.
- In the right note (with properties), the collapsible elements also work normally without scrolling down; however, when scrolling down, clicking on them causes annoying jumps when they expand or collapse.
Y
In notes with properties, collapsible elements should not cause annoying jumps when clicking to expand or collapse them.
In notes with properties, collapsible elements cause annoying jumps when expanding or collapsing them.
Obsidian version: 1.12.7
Installer version: 1.12.7
Language: es
