haffy
April 7, 2025, 9:05am
1
Add this to a custom theme (CSS).
.app-container .workspace .cm-editor .HyperMD-codeblock.HyperMD-codeblock-begin {
margin-top: 1rem !important;
.app-container .workspace .cm-editor .HyperMD-codeblock.HyperMD-codeblock-end {
margin-bottom: 1rem !important;
Add margins (top and bottom) to the codeblock
This adds margin to the codeblock, but also makes the last codeblock non-selecteble.
I think this codeblock in the app.css is the root cause of this, do not exactly know what it does. Maby this could be reviewed?
.markdown-source-view.mod-cm6 .cm-content > * {
margin: 0 !important;
display: block;
When I deactivate that in developer-tools with this code in my css file it works fine.
margin-top: 1rem;
margin-bottom: 1rem;
Maby the app.css code can add somthing to it to be more specific if it is needed?
I have also tried many other ways to add a empty space before and after codeblock, that is what I want. But none works.
dawni
April 7, 2025, 11:46pm
2
This gives you the same appearance while keeping the last line of the code block selectable:
.markdown-source-view.mod-cm6 .cm-content .cm-line:has(+ .HyperMD-codeblock-begin) {
padding-bottom: 1rem;
.markdown-source-view.mod-cm6 .cm-content .HyperMD-codeblock-end {
The downside would be if the :has
noticeably slows down your processes.
FYI, it seems that extending the margin above .HyperMD-codeblock-begin
is the culprit, not the margin below .HyperMD-codeblock-end
, because targeting the previous div and extending its bottom margin also caused the can’t-select issue. Hence my padding-bottom
instead of a margin.
dawni
April 8, 2025, 3:27pm
3
A method that uses neither :has
nor code block margins came to me this morning, and I thought I was brilliant! But it turns out it leaves a little bit of unwanted background color.
You might be able to work with this to fix that piece of background:
.markdown-source-view.mod-cm6 .cm-content .HyperMD-codeblock-begin::before {
content: "\A";
white-space: pre;
display: block;
background-color: var(--background-primary);
.markdown-source-view.mod-cm6 .cm-content .HyperMD-codeblock-end + * {
padding-top: 1rem;
