In my case, when I nest a SystemVerilog code block inside a callout, its code syntax disappeared; the code syntax for SystemVerilog is normal when placing it outside a callout in editing mode, but disappearing in reading mode.
The example code and screenshots are given as following (testing in the sandbox vault):
- code block inside a callout
> [!example] Comments example
> ```SystemVerilog
> module X (input a, output b);
> endmodule
> //single line comments
> //multi-line comments
> first line // you can use `//` to comment anywhere
> second line
- code block outside a callout
```systemverilog
endmodule
second line
In editing mode
In reading mode
- change the code block to another language, for example Verilog, the displaying is normal.
> ```Verilog
> endmodule
> second line
Y
The apearance of a code block inside a callout is normal for all supported coding language.
Obsidian version: v1.7.7
Installer version: v1.7.5
Operating system: Windows 11 Home 10.0.22631
Catalyst license: none
Seen reproduce part
