- Place a code block that uses a language hint inside of a callout.
You can use the following to demonstrate the behaviour inside and outside of a callout:
> [!example]
> Useful for C#, PHP, JavaScript, as well as any other C-based languages.
> ```csharp
> if (condition) return;
> ```php
> if ($condition) continue;
> ```javascript
> if (condition) break;
```csharp
```php
```javascript
Yes, I copied my code into the Sandbox vault running the latest version of Obsidian (1.6.7) and have the same results. I do not use any custom themes/extensions.
I’d expect that the code blocks contained in the callout would keep their language hints
The code blocks within the callout do not have any language hint; also, it may be worth noting that hovering over the code blocks does show the typical ‘Copy’ text.
Obsidian version: v1.6.7
Installer version: v1.5.11
Operating system: Windows 10 Enterprise 10.0.19045
Screenshot of my sample code above:
