I am seeing some strange indenting in the editor when using code blocks.
I have a SQL statement and the initial lines are fine but indented sub-queries are actually indented the wrong way and past the left gutter. See attached screenshot.
Create a code block using 3 back ticks, within the block indent some lines using either spaces or tabs.
Text in indented lines is shifted right.
Text in indented lines is shifted left.
- Operating system: Windows 10, Mac OS
I have the ‘Use Tabs’ preference turned off.
