- Create a code block with a language in live preview mode.
- Select the entire code block, including the first and last lines (the back-ticks) and tab it by pressing tab or
ctrl+] (You would do this if you wanted a code block as part of a list item for example).
- Click on something else to deselect the code block
Text in the right hand corner telling you what language the code block is (the class of this text element is .code-block-flair)
This is what it looks like when it is not tabbed.
No text in the right hand cornewr anymore. The .code-block-flair element is actually still there, it just doesn’t have any text in it.
- Operating system: Windows 10
- Debug info:
Obsidian version: v0.13.14
Installer version: v0.12.15
Legacy editor: off
Snippets enabled: 2
Safe mode: on
For the demonstration screenshots I turned off all my snippets and turned on safe mode to disable all my plugins.
This is a GIF of the problem in action:
