stateDiagram-v2
    [*] --> Service : Request,Event,etc
    Service --> OPA : Query(any JSON value)
    OPA --> Service : Decision(any JSON value)
    OPA --> Policy(Rego) : Check
    OPA --> Data(JSON) : Check
(I had to surround the start and end of the comment in ` to prevent it from being an actual comment block in the forum)
The code block should be commented out.
The code block isn’t commented out.
  • Operating system: MacOS
  • Obsidian version: 0.8.9
You can use triple-backticks to instantiate a code block here. Does the following accurately capture the kind of text you’re having trouble with in Obsidian?
stateDiagram-v2
I realised what the issue was… the issue is with the mermaid stateDiagram and the fact that it includes --> which ends the comment block early…
I can still leave the issue open as it would be nice to be able to comment the mermaid code block but I can see how this is such a narrow bug that it can be safely ignored…
Mods, feel free to close the request if deemed not worthy.
