Click not at the position of cursor
use everforest enchanted theme
add a lot of pictures to a page
Yes i tried. the bug is not there. just with the theme.
that i click and my cursor jumps exactly there
Obsidian version: v1.5.12
Installer version: v1.4.13
Operating system: Darwin Kernel Version 23.4.0: Fri Mar 15 00:10:42 PDT 2024; root:xnu-10063.101.17~1/RELEASE_ARM64_T6000 23.4.0
Community theme: Everforest Enchanted v3.10.0
Snippets enabled: 1
Plugins installed: 9
Plugins enabled: 8
1: Calendar v1.5.10
2: Templater v2.1.3
3: Natural Language Dates v0.6.2
4: PodNotes v2.10.8
5: Note Refactor v1.8.2
6: Excel to Markdown Table v0.4.0
7: Advanced Tables v0.21.0
8: Dataview v0.5.64
https://drive.google.com/drive/folders/1M7Fl1VslBm1JkUKs-pUz90Xq81kBK9LU?usp=drive_link
I know you wrote you check when the error happens in sandbox vault. But how can i get this problem solved? :frowning:
thanks
If the issue is theme specific, I’d report it on their GitHub page so that they can track and have a look at it.
