Click in the left pane, open the right pane
I recently used this feature in several browsers and notion, and it seemed so convenient that I looked to see if it was available in obsidian, but I didn’t find it.
I’m writing this to ask for help from users who have been unsuccessful in their search but know about it.
Thanks in advance.
This feature may be useful.
When opening a note in a new tab, the note will slide from the right.
The feature you pointed out looks very useful.
But I would like a more intuitive way like the one above.
Thank you.
If you CTRL CLICK a link, you get an option to open the link to the right. Does that help?
open to the right in obdidian
You can assign your own hotkey to make this easier:
The one above works with OPT CMD CLICK.
