- Create note.md with this callout:
[!TODO]
- task1
- task2
- task3
- open cmd to use cli and write command:
obsidian tasks list
Result shows correct tasks from note.md
- But it is impossible to mark done or todo using commands:
obsidian task file=“note.md” line=2 done
obsidian task file=“note.md” line=1 todo
Result:
“Error: Line 1 is not a task.”
- Removing of callout cause correct work as usual.
Yes
Use cli task command with callouts.
Error message
Edition Windows 11 Pro
Version 22H2
Installed on 10/17/2023
OS build 22621.4317
Experience Windows Feature Experience Pack 1000.22700.1041.0
