I would like to be able to add not just tags, but manipulate the frontmatter to documents directly via the CLI. I am trying to automate some features for the dataview.
Having a set of new commands on the CLI tools similar to the current tags tool, that let’s me:
Add new fields
Assign values to fields
view field types as a schema
Upsert to fields that are lists
trigger reformat
Currently, I just find the first two occurrences of ---, load with a yaml library, then manipulate the file directly. It’s doable, but a pain when I could just upsert the new fields I’d like directly.
EDIT: I just saw WhiteNoise’s reply above; I didn’t realize the CLI could already do this. Neat!
A workaround I use is yq, a command line tool for manipulating YAML files (and JSON, XML and more).
It’s relatively easy to use yq to, say, mass-update a frontmatter field, delete a field, or manipulate list fields.
For example, here’s a bash command to update all the md files in a directory and rename a field from “topics” to “related”. It does this by setting the “related” field and then deleting the “topics” field.
