CJK: wrong rendering in edit mode for bolded wikilinks
copy this to note:
  • 这是**[[一个]]**测试
The part “一个” should be bolded in edit mode, and the part “测试” should’t be bolded.
The part “测试” is bolded in edit mode, while the part “一个” isn’t bolded. Meanwhile, it works rightly in preview mode.
Pasted image 20210711012822
  • Operating system: windows 10
  • Obsidian version: 0.12.5
This problem only happens in chinese like input, so I can fix it by adding space, just like this:
  • 这是 **[[一个]]** 测试 → It’s ok
And if I don’t use wikilink, nor the problem appear
  • 这是**一个**测试 → It’s ok
I have closed all third-party plugins and used default css.
I hope I express problem clearly, thanks for your help.
I also have this bug +1
Because English punctuation is usually followed by a space, it can comply with compliant. However, in the Chinese environment, there will be no spaces after punctuation. If I force the addition of spaces, strange spaces will appear between sentences.
Must we fully comply with commonmark? It seems that only preview mode is unique.
**中文使用全角标点,**一
have space
without space
zero width space is good
Bold failure in Chinese sentence, because of the usage of Chinese punctuation is different from English - Spec - CommonMark Discussion
bold with [[]]:
link is right, but without strong
<> with [[]]:
link is wrong
but in preview mode all are right.
OS: win10
Version: 0.13.14
Live Preview mode
Another problem caused by the Chinese punctuation. When editing a checkbox bullet, once I enter the Chinese comma, the next character entered will be moved to the start of the bullet and the checkbox will be degraded to the common bullet.
pHQI49h9qv
I have a same issue. I am Korean user.
I think add \u200B to punctuation in markdown.js can resolve this bug.
After add this regex, we can add zero width space.
punctuation = /[!"#$%&'()*+,\-.\/:;<=>?@\[\\\]^_`{|}~\xA1\xA7\xAB\xB6\xB7\xBB\xBF\u037E\u0387\u055A-\u055F\u0589\u058A\u05BE\u05C0\u05C3\u05C6\u05F3\u05F4\u0609\u060A\u060C\u060D\u061B\u061E\u061F\u066A-\u066D\u06D4\u0700-\u070D\u07F7-\u07F9\u0830-\u083E\u085E\u0964\u0965\u0970\u0AF0\u0DF4\u0E4F\u0E5A\u0E5B\u0F04-\u0F12\u0F14\u0F3A-\u0F3D\u0F85\u0FD0-\u0FD4\u0FD9\u0FDA\u104A-\u104F\u10FB\u1360-\u1368\u1400\u166D\u166E\u169B\u169C\u16EB-\u16ED\u1735\u1736\u17D4-\u17D6\u17D8-\u17DA\u1800-\u180A\u1944\u1945\u1A1E\u1A1F\u1AA0-\u1AA6\u1AA8-\u1AAD\u1B5A-\u1B60\u1BFC-\u1BFF\u1C3B-\u1C3F\u1C7E\u1C7F\u1CC0-\u1CC7\u1CD3\u2010-\u2027\u2030-\u2043\u2045-\u2051\u2053-\u205E\u207D\u207E\u208D\u208E\u2308-\u230B\u2329\u232A\u2768-\u2775\u27C5\u27C6\u27E6-\u27EF\u2983-\u2998\u29D8-\u29DB\u29FC\u29FD\u2CF9-\u2CFC\u2CFE\u2CFF\u2D70\u2E00-\u2E2E\u2E30-\u2E42\u3001-\u3003\u3008-\u3011\u3014-\u301F\u3030\u303D\u30A0\u30FB\uA4FE\uA4FF\uA60D-\uA60F\uA673\uA67E\uA6F2-\uA6F7\uA874-\uA877\uA8CE\uA8CF\uA8F8-\uA8FA\uA8FC\uA92E\uA92F\uA95F\uA9C1-\uA9CD\uA9DE\uA9DF\uAA5C-\uAA5F\uAADE\uAADF\uAAF0\uAAF1\uABEB\uFD3E\uFD3F\uFE10-\uFE19\uFE30-\uFE52\uFE54-\uFE61\uFE63\uFE68\uFE6A\uFE6B\uFF01-\uFF03\uFF05-\uFF0A\uFF0C-\uFF0F\uFF1A\uFF1B\uFF1F\uFF20\uFF3B-\uFF3D\uFF3F\uFF5B\uFF5D\uFF5F-\uFF65]|\uD800[\uDD00-\uDD02\uDF9F\uDFD0]|\uD801\uDD6F|\uD802[\uDC57\uDD1F\uDD3F\uDE50-\uDE58\uDE7F\uDEF0-\uDEF6\uDF39-\uDF3F\uDF99-\uDF9C]|\uD804[\uDC47-\uDC4D\uDCBB\uDCBC\uDCBE-\uDCC1\uDD40-\uDD43\uDD74\uDD75\uDDC5-\uDDC9\uDDCD\uDDDB\uDDDD-\uDDDF\uDE38-\uDE3D\uDEA9]|\uD805[\uDCC6\uDDC1-\uDDD7\uDE41-\uDE43\uDF3C-\uDF3E]|\uD809[\uDC70-\uDC74]|\uD81A[\uDE6E\uDE6F\uDEF5\uDF37-\uDF3B\uDF44]|\uD82F\uDC9F|\uD836[\uDE87-\uDE8B]/
For all the people who landed here. There are two issues in this BR. The first of which is really related to the markdown spec.
For the editor:
  1. Markdown: Treat CJK punctuation symbols as letters
  2. Editor / Live Preview: Markdown markers are applied forward, even if there is no closing marker
Reading mode is also incorrect according to markdown spec in this example.
