Been trying to set up obsidian on my chromebook
Found that none of the plugins or settings save, so it resets to defults every time i swithc it on and off.
I think its due to the .obsidian folder being hidden, however i cant find anyway of unhiding the file without renaming the .obsidian folder.
Is there a way to let obsidian read hidden files? or a way to alter the way it works so i can rename the .obsidian folder to something without the dot that makes the file hidden?
  1. To see the .obsidian folder in ¨Files":
    Click on the hamburger menu ¨…" top right
    Click on “Show hidden files”
  2. I placed the Obsidian Vault in my Chromebook in
My files > Downloads > _myObsidian > O_TEST
My Obsidian plugins & settings save properly - I do not have to reset them each time.
JoeC1, are you using the Android Obsidian app or the Linux one?
