Chinese input method position drift
使用中文输入法输入内容。
Y
中文输入法不漂移。
20241227_033736
Obsidian version: v1.8.0
Installer version: v1.7.7
Operating system: Darwin Kernel Version 24.3.0: Mon Dec 9 19:48:58 PST 2024; root:xnu-11215.80.25.501.2~1/RELEASE_ARM64_T8112 24.3.0
Catalyst license: insider
Insider build toggle: on
Did this start to happen recently or you always had this problem?
I encountered the same issue, which appeared in version 1.8.0 and is difficult to reproduce. It mainly occurs when using multiple screens and multiple references, where the cursor position often does not match the input position.
I repeatedly clicked and confirmed the input position with the mouse, ensuring it was where the cursor was located. However, it still inputs in the wrong place, while the cursor position remains unchanged.
This issue doesn’t seem to be limited to Chinese input methods; it also appears to affect English input.
After 1.8.0.
I reverted to version 1.7.7, and there are no issues. I will stick with this version until it is fixed.
This is due to an upgrade to CodeMirror and tracked in an erronously closed bug report here:
It is caused by an underlying Chromium bug that is tracked here:
https://issues.chromium.org/issues/351029417
We will try to work around the issue for now.
Japanese IME has the same issue. This issue affects not only Chinese lang users, but also all IME users.
Obsidian version: v1.8.1
Operating system: Darwin Kernel Version 24.2.0: Fri Dec 6 19:01:59 PST 2024; root:xnu-11215.61.5~2/RELEASE_ARM64_T6000 24.2.0
