Hi, for my use case it is important to see what direction the edges in graph view are going.
I considered adding a directed color gradient in each edge, or enlarging the arrows.
Any suggestions on what CSS properties I could use to achieve this? I tried digging around in the element inspector but the whole graph was in an canvas element.
The only CSS properties exposed for customization are node colors. See Plugins/Graph view.md in the help vault.
You can change the size of the arrows with the Link thickness slider in the graph Display options.
Beyond that, you’ll need to make a feature request.
