I did some small changes to a code found here to change the block quote colour in edit mode. It can also be used to change font
Block quote
/* for editor */
.cm-quote {
color: var(--text-normal) !important;
/* for preview */
.markdown-preview-view blockquote {
background-color: #ece8f8;
border: 0px solid;
border-color: #baa7ec !important;
border-left-width: 5px !important;
border-radius: 0 8px 8px 0;
font-family: ;
color: black;
font-size: 15px;
line-height: 1.5em;
margin: 10 10px;
padding-top: 10px;
padding-bottom: 10px;
/* Vertical centering of text in blockquote */
blockquote {
display: flex;
flex-direction: column;
justify-content: center;
Blockquote as per Obsidianite
/* in Edit mode */
.cm-quote {
/* color: purple ; /*var(--text-normal) !important; */
border: 0px solid;
border-left-width: px !important;
font-family: ;
color: black;
font-size: 15px;
line-height: 1.5em;
margin: 10 10px;
padding-top: 10px;
div:not(.CodeMirror-activeline)>.CodeMirror-line span.cm-formatting-quote {
color: transparent !important;
display: inline !important;
div:not(.CodeMirror-activeline)>.HyperMD-quote {
border-left: 4px solid var(--text-selection);
/* border-color: black var(--text-accent); */
border-top-right-radius: 5px;
border-bottom-right-radius: 5px;
border-top-left-radius: 3px;
border-bottom-left-radius: 3px;
line-height: 1.3em;
padding: 12px 0px 15px 8.5px; /* or 12px 15px 15px 8.5px ? */
margin-right: 15px !important;
margin-left: 15px !important; /* or 5px ? */
border-top: transparent;
border-bottom: transparent;
background: #ece8f8; /*linear-gradient(120deg, rgba(170, 167, 236, 0.9), var(--text-faint));*/
display: inline-block;
/* div:not(.CodeMirror-activeline)>.HyperMD-quote::before {
content: '';
position: absolute;
top: 0;
left: 0px;
height: 2px;
width: 60%;
background: linear-gradient(90deg, var(--text-accent), var(--text-faint));
div:not(.CodeMirror-activeline)>.HyperMD-quote::after {
content: '';
position: absolute;
bottom: 0;
left: 0px;
height: 2px;
width: 25%;
/* in Preview mode */
position: relative;
padding: 1rem 2rem 1rem 3rem;
color: white; /* #bdbdbd */
line-height: 1.4em;
margin-bottom: 2em;
border-left: 4px rgba(31, 178, 129, 0.9) solid;
background: linear-gradient(135deg, var(--base4), var(--base3));
border-right: transparent;
margin-right: 0 !important;
.markdown-preview-view blockquote::before {
content: '';
position: absolute;
top: 0;
left: 0px;
height: 2px;
width: 60%;
background: linear-gradient(90deg, rgba(31, 178, 129, 0.9), var(--base3));
.markdown-preview-view blockquote::after {
content: '';
position: absolute;
bottom: 0;
left: 0px;
height: 2px;
width: 25%;
.markdown-preview-view blockquote p {
position: relative;
Quotation marks
/* from https://forum.obsidian.md/t/meta-post-common-css-hacks/1978/39 */
/* Add quotation character before quote */
blockquote:before {
font: 14px/20px italic Times, serif;
content: "“";
font-size: 3em;
line-height: 0.1em;
vertical-align: -0.4em;
blockquote p { display: inline; }
/* as per Obsidianite /
/ in Edit mode */
div:not(.CodeMirror-activeline)>.HyperMD-quote>span:first-of-type::before {
content: '“' !important;
font-weight: 700;
font-size: 3em;
color: var(--text-accent);
left: 3px;
top: 15px;
position: relative;
.markdown-preview-view blockquote p:first-of-type::before {
content: '“';
font-weight: 700;
font-size: 3em;
position: absolute;
top: 0.1rem;
left: -1.8rem;
Signature: name of the person quoted
Put this code in the CSS sheet (courtesy Gabroel)
/* signature inside the blockquote*/
.signature {
font-family: "SignPainter"; /**Choose a cursive font */
text-align: right;
Then, in the note, at the end of the blockquote put this:
`<div class="signature">- Name </div>`
if you want the font size of the signature bigger, use this instead:
`<div class="signature"> <span style="font-size:25px">- Name</span> </div>`
OR, without the css code and the div rule, you can simply write at the end of the blockquote:
<cite> — Name </cite>
which puts the name in italics, though unstylised, and thus differentiates it from the quote.
