Certain LaTeX symbols not rendered
The red marked entries in the screenshot are of interest.
I tested this in the Sandbox vault with no plugins enabled where my screenshot is from.
I am not sure if a negated Unifying Quantifier exists because i didnt find the symbol in my lists i just assume it exists. The others definitely do exist.
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: Windows 10 Home 10.0.19045
Legacy editor: off
issue resolved you have to type
\not\forall
\not\ni
\not\subset
\not\supset
for some reason. I hope somebody can learn quicker from this thread than me it took me an hour.
\not is documented in MathJax basic tutorial and quick reference
Yeah thanks i just dont understand why some symbols have short codes or multiple (+3) ways to write it and some dont.
ive noticed that nearly everything works with \not before the actual code but only a few with ā€œ\nā€
I know there are a lot symbols that are the same but just a different size or font i didnt mean them. Ive looked up your links and saved them :slight_smile:
