Hey! I use Obsidian quite a lot (thanx for the great program) and I move obsidian screens quite a lot and at the same time I use obsidians feature to display multiple notes side by side. But often I need to move the divider between the files to one side to get a better view of one of the sides, but afterwards If I want it moved back its no longer centered ):
I think the usability would improve greatly if the user would be able to double tap the divider between the two files to perfect center it again (In the program of course not the full viewwindow, im not a monster). So i nog longer have to close every note in one of the panes to get the equal divide back.
And I would if you have more than 2 notes open or also vertically It would just perfectly dive across the axis at which you tried to double click.
Alternatively you could do it via a context menu? But that sounds less convent to me
Cheerio!
