Create a vault with the same name as an exiating vault with different capitalization.
Yes.
Either the inability to create the second vault or a fresh vault being created.
A new vault is created in the ui with the new capitalization with the same files backing both the new and old vault.
Obsidian version: 1.12.4 (299)
API version: 1.12.4
Operating system: Android 16 (samsung SM-S928U)
Webview version: 145.0.7632.120
Catalyst license: none
These cloned vaults behave unintuitively, changes in one are reflected in the other, and deleting one deletes both (unfortunately the reason I discovered this lol). Cloned vaults can be created in a similar manner via setting up sync. This happened on Android, but I suspect it is a possibility on any platform where a case insensitive file system is possible.
