- Open Obsidian (tested on Windows 11).
- Create or open a Canvas.
- Create a connection line between two cards and double-click the line to add/edit a connection label.
- Type a label, then press the Escape key to attempt to end editing.
Did you read and follow the Troubleshooting Guide ? Yes
According to the official documentation, pressing Escape should submit/save the text and close the active edit text box: “Enter the label and then press Escape or select anywhere on the canvas.”
The Escape key does nothing. The focus remains completely locked inside the label text-editing box. Typing continues to alter the text. Editing can only be ended by clicking on empty canvas grid space.
Obsidian version: 1.14.4
Installer version: 1.14.4
Operating system: Windows 11 Home 10.0.26300
Catalyst license: insider
Insider build toggle: on
Confirmed this behavior persists inside a completely clean Sandbox Vault with all third-party plugins, custom themes, hotkey configurations, and external window/keyboard managers (like AutoHotkey and PowerToys) entirely disabled or suspended.
