Canvas: Edge disappears after creating a node via edge dragging in Obsidian version 1.11.X
In Canvas, we can no longer directly create a new node after dragging to create a new edge, as the edge disappears. This is a bug in Obsidian v1.11.X that was not present in previous versions.
Demo:
demo
Add card is working on my end but not Add note from vault.
Obsidian_uZ3KE3UZhu
The team may be aware of this issue, but please paste in the output of the Show debug info command as asked for in the bug report template. Thanks!
Here’s mine:
	Obsidian version: v1.11.5
	Installer version: v1.10.6
	Catalyst license: supporter
	Insider build toggle: on
	Plugins installed: 0
	Plugins enabled: 0
Thank you for your kind reminder.
In Windows 11, I encountered the same situation as you, where adding a card works but adding a note does not.
	Obsidian version: v1.11.4
	Installer version: v1.9.10
	Catalyst license: none
	Plugins installed: 17
	Plugins enabled: 0
I’ll add the debug info from my Macbook later.
Just noticed there’s a report for this already:
