Create a Canvas. Create a group. Create a card and place it inside the group. Attempt to connect the group to the existing card. It does not work.
Y
A connection between a connection node of the group and a connection node of the card with the origin of the connection pointing inwards.
Obsidian cannot detect a connection point of the card when it’s inside of the group. Attempting to make a connection just prompts the user to create a new card.
If making a connection between the group and card when the card is outside of the group, the arrow from the group first goes out and then loops back in.
Obsidian version: v1.4.16
Installer version: v1.4.13
Operating system: Windows 10 Education 10.0.19045
Catalyst license: none
Legacy editor: off
