Canvas can't embed specific Base view like SomeBase.base#SomeView
Open Obsidian
Create a Base with more than one View
Create a Canvas and embed the Base
Try modifying the canvas JSON to change the “file” attribute from SomeBase.base to SomeBase.base#SomeView
Yes
Should be possible to select which Base view to load when loading the Canvas.
Always loads the Base’s default view when the Canvas loads. If I add #SomeView to the filename it won’t load the Base at all.
Obsidian version: 1.12.7
Installer version: 1.12.7
Operating system: #1 SMP PREEMPT_DYNAMIC Thu, 30 Apr 2026 18:41:12 +0000 7.0.3-arch1-1
Plugins installed: 20
Plugins enabled: 17
1: Advanced URI v1.46.0
2: Emoji Shortcodes v2.2.0
3: Pandoc Plugin v0.4.1
4: Google Calendar v1.10.16
5: Heading Shifter v1.9.0
6: Dataview v0.5.68
7: Todoist Sync v2.2.1
8: Templater v2.16.2
9: Fit v1.4.0
10: GitHub Link v1.2.0
11: BRAT v1.3.0
12: Excalidraw v2.16.1
13: Calendar (Beta) v2.0.0-beta.2
14: GH Links Shortener v0.1.0
15: @ Symbol Linking v2.1.0
16: Local REST API v3.2.0
17: Claude Code Integration v2.0.0
I consider this a bug because:
  1. Thread t/bases-extend-functionality-of-view-referencing-when-embedding-a-base-in-canvas-files/102567 reported the same thing with the solution “will be implemented in v1.9.5”
  2. The same #SomeView syntax works for embedding in a note, just not in a Canvas
I think you are looking for the right-click on a .base → Pin view... option.
CleanShot 2026-05-10 at 07.51.42
