  1. Make a header with space and use the jump to header thingy. Just like this:
[Jump to me](#jump-to-me)
#### Jump to me
Good job!
  1. Click the Jump to me and It should jump on the header.
Does not jump to the header.
It should jump to the header.
  • Debug info:
	Obsidian version: v0.13.33
	Installer version: v0.13.23
	Operating system: Windows 10 Pro 10.0.19044
	Legacy editor: off
	Safe mode: off
	Plugins installed: 3
	Plugins enabled: 3
		1: cMenu
		2: LanguageTool Integration
		3: Advanced Tables
	Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the help vault or disable community plugins.
It would be really awesome If you can jump to headers that has spaces in Obsidian(Markdown) and if the reproduce is still to little to be understood somehow.
  1. Copy and paste this Ultimate Privacy Guide by All0cation from Github to Obsidian.
  2. Click any jumpers that has space in the Contents and It won’t jump.
As an alternative, you can use [[page#jump to me]] to get the right result. Though with that markdown document you linked, you obviously can’t do that.
If I use that, Github and other markdown stuff won’t be able to parse it. Using:
#### Jump to me
Good job!
Seems to work in markdownlivepreview.com and platforms such as Github, Gitlab & etc
true, there is definitely an issue, just suggesting a compromise.
I understand anyways thank you!
This is not a big. We don’t support that format. Check out the docs.
But this feature will be really useful for people who uses Obsidian as a markdown editor for their Github & etc.
Please, search/open a feature request
