- Open any long note on iOS or iPadOS.
- Make sure you’re using the default Obsidian theme and your device is in light mode (or automatic mode when it’s during the day).
- Notice that because the scrollbar is dark, you can’t see it.
Yes.
The scrollbar should always be light when using the default Obsidian theme (or any dark theme) so it’s visible.
The scrollbar is dark and therefore not visible.
Operating system: ios 16.6.1 (Apple iPad)
Obsidian version: 1.4.8 (107)
API version: v1.3.7
Live preview: off
Legacy editor: off
Notice that if you put your device in dark mode, the scrollbar becomes visible (because it becomes light).
