Can not indent code block without a list
What have I searched
this uses a list to indent a code block.
but I want to indent code block without list…! is this possible?
is this intended behavior?
I want code block to be indented without a list
it looses syntax highlight when I indent it
Obsidian version: v1.3.7
Installer version: v1.3.5
Operating system: Darwin Kernel Version 22.3.0: Mon Jan 30 20:38:37 PST 2023; root:xnu-8792.81.3~2/RELEASE_ARM64_T6000 22.3.0
Legacy editor: off
Plugins installed: 1
Plugins enabled: 1
1: Obsidian Git v2.20.7
Indentation by itself marks a block as code. So if you indent a fenced code block, you’re marking the backticks as code too.
If you want all code blocks to be indented more, you can use a CSS snippet to do that.
If you only want to indent some code blocks, you’ll need to explain in more detail what you’re trying to accomplish.
If you want to only indent in editing view, you can indent by up to 3 spaces without triggering a code block. The indentation will not appear in reading view.
Also, of course, indentation is preserved within code blocks.
