Camel Case Autocorrect
I am a person that uses camel case when making there files (example: thisIsAnExampleFileName) and it currently gets marked down as being spelled wrong which means I have to add it to my dictionary to get rid of the red lint.
I would treat the shift in capitalization as a space in the auto-correct eyes, this would let it only be triggered by incorrect spellings of the individual words of the file’s name. I believe this is somewhat similar to how its treated in most developer IDEs
I currently individually add each file name to my dictionary so that it doesn’t show up as misspelled
If you’re on iOS (and I assume Mac?) it will eventually learn the ones you use frequently (which doesn’t help with rarer ones, but it’s something).
