I get a callout, 2 blank lines, and a block quote with the table.
Obsidian version: v1.10.1
Installer version: v1.8.10
Operating system: Darwin Kernel Version 21.6.0: Wed Aug 10 14:28:25 PDT 2022; root:xnu-8020.141.5~2/RELEASE_ARM64_T8110 21.6.0
Catalyst license: vip
Insider build toggle: on
If I select the table from the top-down (using shift ↓) I can reproduce the issue, but it looks like if I select the table from the bottom-up, it is wrapped in the callout as expected.
Obsidian version: 1.14.1
Installer version: 1.13.7
Operating system: Darwin Kernel Version 27.0.0: Tue Aug 11 21:22:49 PDT 2026; root:xnu-13432.1.9~1/RELEASE_ARM64_T6000 27.0.0
I’m facing the same issue with Obsidian v1.14.5, Windows 11.
I’m pasting text including tables from external sources and put then in a callout on a regular basis and blank lines get added before the table, which breaks the callout. It happens regardless of the direction of my selection (from top to bottom or from bottom to top). This is not the expected behavior. This doesn’t make Obsidian unusable but it is a little annoyance.
