Callout toggle text seems to display artifacts
As can be seen in the image, the text inside the normal callout (above) displayed normally, but the ones inside the toggle callout (below) displayed artifacts.
I’m am using a fresh vault with only this snippet to narrow down the cause:
.callout:is([data-callout="toggle"], [data-callout="toggleh4"]) {
  background-color: #383836;
  border-radius: 0px !important;
  border-color: #383836 !important;
.callout:is([data-callout="toggle"], [data-callout="toggleh4"]) .callout-title-inner {
    color: #f0efed !important;
Step 1
Simply create a toggle callout and use the snippet above .
Step 2
Type something inside the toggle callout (texts, bullets etc.) and in the note itself (outside the toggle callout). Why is this step important? Because I noticed, when the toggle callout is in an empty note, the text on the toggle callout title seems to be fine.
Step 3
Turn on Reading Mode (Live Preview seems to be fine, these artifacts only appear in Reading Mode.)
Step 4
Take a screenshot and zoom in.
The reason I’ve narrowed it down to this snippet:
Is because once you remove “background-color” from the code, the text on toggle callout seems to display normally.
Obsidian version: 1.12.7
Installer version: 1.12.4
Snippets enabled: 1
Plugins installed: 0
Plugins enabled: 0
