Callout Styling help
I’m using the code below to style my callouts. However, I’m having trouble getting the icon and label where I want them. I’m sure it’s something super simple that I’m just overlooking, but any help would be appreciated.
This is the code:
body.markdown-preview-view .callout-icon > svg {
  width: 36px;
  height: 36px;
.callout > .callout-title > .callout-icon {
  --icon-size: 36px;
  opacity: 0.8;
  position: relative;
  float: right;
.callout[data-callout-metadata*="label"] {
  --block-spacing: 1rem;
  --speaker-block-width: 20%;
  margin: 0px;
  padding: 0px;
  display: grid;
  grid-template-columns: var(--speaker-block-width) calc(100% - var(--speaker-block-width));
  background-color: var(--background-primary);
  border: none;
.callout[data-callout-metadata*="label"] .callout-title {
  display: inline-block;
  height: calc(100% - var(--block-spacing));
  text-align: right;
  border-right: 3px solid;
  padding-right: var(--block-spacing);
  flex: 1 0 auto;
.callout[data-callout-metadata*="label"] > * {
  margin-top: var(--block-spacing);
.callout[data-callout-metadata*="label"] > .callout-content {
  padding: 0px var(--block-spacing);
.callout[data-callout-metadata*="label"] > .callout-content > p:first-child {
  margin-top: 0px;
.callout[data-callout-metadata*="label"] > .callout-content > p:last-child {
  margin-bottom: 0px;
.callout {
  position: relative;
And this is what it looks like
Screenshot_2025-03-28_15-00-01
I am trying to get the icon to sit on the first line, then the label to show on the next line underneath
You could try something like this:
  --speaker-block-width: 15%;
  margin: 0px;
  padding: 0px;
  display: grid;
  border: none;
  padding-left: 35px;
.callout[data-callout-metadata*="label"] > .callout-title > .callout-icon {
  --icon-size: 30px;
  opacity: 0.8;
/* optonial if you need a bit more spacing between the icon and title */
/*.callout[data-callout-metadata*="label"] .callout-title-inner {
   padding-top: 5px;
  margin-top: 0px;
  margin-bottom: 0px;
This worked perfectly! I did have to add ‘float:right’ to the .callout-icon element to get it where I need it, but this fixed the problem I had with the icon and title overlapping.
Thank you!
